Ive done a bunch of reading, poking at the heating and scratching my head (not my area of expertise at all - but Ive learned a bit reading here).
Fundamentally, the problem is that the heating is only half-working - radiators are only just warm - and the house is cold. However, the twist is that now and then, it works fine! (occasionally, the hot water isn't so hot either, so I don't think its just the heating)
The boiler is a Potterton Suprima (70, I think). I think its 2007 vintage...
From what Ive observed of the boiler, it comes on for only 30 seconds (i.e. flames for 30 seconds, plus the 10-second verification the fan is on). It then goes off for about 4 minutes. If I understand the diagnostic LED correctly, it thinks its reached the desired temp. (slow flashing green).
The boiler thermostat is set to max.
The heating thermostat is set to max.
The pump (grundfos) appears to be working ok...
The motorised valves appear to be working ok...
Its a sealed system. The pressure might have been a bit low - but its ok now.
When the boiler is not firing, the in/out water pipes are luke-warm. When the boiler fires, the outflow pipe gets hot - as you would expect.
The inflow pipe is luke-warm - and hasn't really changed in temp before the boiler stops firing. When the boiler stops firing, the outflow pipe quickly cools to luke-warm again.
When the boiler is working properly - i.e. heating working, and boiler staying on more than 30 seconds, the in/out pipes are hot.
I can't think of any other relevant info to add...
Any suggestions?
Is the pump faulty - i.e. not shifting the heated water quickly enough to prevent the boiler reaching temp? After what time/temp should the boiler re-fire after it shuts down.
Is the temp sensor on the boiler not working properly?
Any ideas greatly appreciated.
Cheers.
Any suggestions?
Cheers.
