I have a property with solid stone walls. It was built in the 1920s. The damp is coming up through the solid floors and through the walls. My solution is to take up the floors and replace with wooden floors using 100mm celotex under. The new joists will be on new concrete walls not touching the outside wall. I will then put air bricks in the walls to create air flow. I will use battens on the walls with 25mm celotex and vapour check plasterboard, creating air gaps behind the board from the ground floor into the loft. The outside will then be painted with a water based paint. My intention is to create an inner envelope of celotex and fibreglass but allow the air to ciculate under the floors and behind the plasterboard. Can anyone tell me a flaw in this method. Thanks
