Hi all,
Brace yourselves for a borathon but I'm guessing devil is in the details with system design.
I have an old stone cottage in Somerset, no gas in village, no room for an oil tank - 3 bed, 2 bathroom. Currently heated by storage heaters and an old, tiny woodburner (all downstairs). DHW is provided via a small tank with a 3kW immersion.
My girlfriend and I love the place. Love the single glazed wooden windows, old stable doors, stone unplastered feature walls etc. I know that I need to insulate as much as possible and I am in the process but the bottom line is that trying to keep this place to a constant 20 degrees without destroying the reason we bought it would probably require enough kWhs to warrent building my own nuclear power station.
So we're going to be cold. Fine. Luckily we work long hours and the offices is heated.
What would suit us is a system which can provide high output heat when we need it. The upstairs is less of an issue (at present we sparingly use oil filled electic heaters when it's too cold to sleep) so anything is better than them. I would be happy with 3 x 3kW upstairs (one in each bedroom) - which would only be used sparingly.
The woodburner's had it, and the chimney is slap bang in the middle of the downstairs so I'm thinking double-sided stove. We also lack a DPC so in the process of putting one in, I'll be insulating the ground floor and so I have the opportunity to install underfloor heating - which although isn't anywhere near enough to heat the place, will take the chill off the floor.
So, I'm not sure whether I just install electric underfloor heating downstairs (for the mornings) and put some electric rads upstairs (forget storage heaters we're both working 12 hour days and those things always trickle the heat out during the day no matter what).
OR, whether I install wet underfloor heating and get a stove with a back-boiler to run the underfloor heating (via a vented cylinder which has back-up immersion heaters). I have looked at a Boru stove which is supposed to give 14kW to water and 4kW to the room which as we sit real close to the stove, sounds like a reasonable option.
Or, shall I go for loads of Propane bottles and a massive Combi? (not sure if I've got space for the bottles)
I'm happy for you all to laugh at my predicament, but no abuse please or I'll go electric only and destroy the whole planet with my carbon footprint.
