i know this has been asked a million times, but i have done a some research, and things get a bit conflicting and confusing at times.
so anyhoo
before i moved into my house the previous owner had removed an old cast concrete garage, to this garage was 2.5mm swa cable.
i want to now relocate this swa cable into my shed, so i can run 2 double sockets in the shed and 2 double sockets on the decking out side.
(the existing swa cable is wired in to the main consumer unit with its own rcd at one end, and currently bare the other)
8 low power led lights on the decking and 1 light in the shed.
i want to run the swa cable into a small consumer unit and then run 2 different circuits, 1 for lighting and 1 for power sockets.
the total run of cable is about 25 meters.
the most these sockets will run is a 900w sds power drill and that would be occasionly, i mainly want the sockets so i can plug in laptops and charge up power tool batteries.
i have been on tlc-direct.co.uk and there calculator says the minimum cable thickness of 2.5mm can take 4kw of power, i dont ever intend on using this much power in the shed.
my intention is to install all the cables etc and then get an electrician round to wire the consumer box and check everything.
hopefully i have written all the needed information, and any help would be appreciated.
so anyhoo
