That first draft ( or daft ) also made the installation of telephone wiring notifiable.
We've been through this before.whilst a Judge can, as you say, say strong things about/to the legislators, (s)he would have no authority to 'over-ride' what was ('clearly') written.
I remember.That first draft ( or daft ) also made the installation of telephone wiring notifiable.
That's not what my legal contacts tell me. My understanding in that our (unwritten) constitution takes very seriously the 'separation of powers between the Judiciary and the Executive', such that the former are not allowed to second-guess what the latter should have written (and maybe 'intended to write'), when they actually wrote something which was (clear and) different. My understanding is that only if there is a lack of clarity or ambiguity etc. (or 'silence' about a particular situation) are the Judiciary allowed to 'interpret'.We've been through this before. They can, and they have, passed judgements on the basis of what they thought Parliament intended.whilst a Judge can, as you say, say strong things about/to the legislators, (s)he would have no authority to 'over-ride' what was ('clearly') written.
In England:The statutory instrument which added the new rules under regulation 12 and removed the old requirements from schedule 4 also appears to have completely deleted para. 3 of the latter which is where the exemption for such wiring was to be found:
That's rather my point: The new regulation just says that notifcation is required where the work involves the installation of a new circuit. I don't see anywhere in which it says that such notification is not required if that new circuit is for telephone, data, or some other similar function rather than for supplying power.Schedule 4 no longer exists but was a list of work NOT notifiable.
Now there is just a list of three which ARE notifiable.
Exactly. If it was "....unclear from the wording of the act whether or not it could also be used to protect companies from harassment...", then a Court has a perfect right (and duty) to make a judgement on the basis of its interpretation of what was intended. However, if the wording of the Act, as written and enacted, had been clear in saying that companies could be protected (even if that had not been the 'intention of Parliament'), then a Court would, as I understand it, have been powerless to give judgement on any other basis, even if they strongly believed that the wording of the Act did not properly reflect "the intention of Parliament". As I said, a Court can (and must) interpret unclear or ambiguous law, but it cannot "re-write the law". Even the Supreme Court cannot do that.The Protection from Harassment Act 1997 prohibits a course of conduct which causes harassment, alarm or distress. But it was unclear from the wording of the act whether or not it could also be used to protect companies from harassment. In a case before the High Court it was decided that companies could not be protected, as this was not the intention of Parliament when passing the legislation.
I see, interesting. I suppose it is an electrical installation.That's rather my point: The new regulation just says that notifcation is required where the work involves the installation of a new circuit. I don't see anywhere in which it says that such notification is not required if that new circuit is for telephone, data, or some other similar function rather than for supplying power.
It sure seems as though somebody didn't really think it through when writing the amendment since, as you say, it seems unlikely with the relaxation of the rules it was really the intent to make communication circuits notifiable. But then that's so often the case with badly drafted regulations.Another anomaly?
Indeed. Dare I suggest that it's quite likely that the person(s) who drafted the amendment didn't even realise that the scope of the regulations included communication circuits etc.?It sure seems as though somebody didn't really think it through when writing the amendment since, as you say, it seems unlikely with the relaxation of the rules it was really the intent to make communication circuits notifiable. But then that's so often the case with badly drafted regulations.
If you put a consumer unit in there, it is notifiable.
If you do not, it is not.
To my mind a lot of this is pretty silly, but, since you mention the above, FWIW, Approved Doc P says "Installing fixed electrical equipment is within the scope of Part P, even if the final connection is by a standard 13A plug and socket, but is notifiable only if it involves work set out in regulation 12(6A)" ... and, of course, regulation 12(6A) includes "replacement of a consumer unit"!That seems a tad silly John when it's a replacement that I assume is fed of a circuit from the main DB , one could technically wire a CU to a 13A plug what surely would not be notifiable right?
(aka Flameport)That seems a tad silly John Ward
Though when writing an amendment which deletes a section of schedule 4 and said section refers explicitly to such wiring, you'd think the penny would drop.Dare I suggest that it's quite likely that the person(s) who drafted the amendment didn't even realise that the scope of the regulations included communication circuits etc.?
