- Joined
- 28 Jan 2020
- Messages
- 5
- Reaction score
- 0
- Country
We are refitting the main bathroom and want to install a 10.5kw electric shower - the Mira Dual Decor to be precise. A new 10mm cable is being installed from the consumer unit. The run is about 11m. It runs through wood / plasterboard and does not touch any other cables along its run. Once in the bathroom it runs through a stud wall - again no other cables present and no insulation along its length. It will obviously be on its own circuit and a currently unused MCB in the consumer unit will be upgraded to 50a - the recommended is 45 but wylex don't seem to make one. There will obviously be a separate pull cord switch in bathroom for the shower. This is all in the planning stage but is there anything else I should be thinking about/need to consider?
thanks in advance
thanks in advance
