Because it's low-expansion and quite easily controlled, you get a good idea of the bead size when you are spraying.Glad you mentioned Soudal as I've just bought some but unfortunately our local B&Q were out of stock. How big should the bead be to ensure a gap fill of 10mm?
No its solid once dry. You'll go quicker if you put some fixers in as you go to hold it while it cures.
It sets hard.
