I have a 1930s semi with a minor damp problem on the front 2 walls.
The house is situated quite low down, around 1-2 feet lower than the path infront of the drive. I am currently addressing the drainage and I am going to dig away and lay course gravel then a top layer of finish gravel around the brick work of the house. Currently there is around 2 inch of finish gravel and some slabs laid poorly around the brickwork.
The previous owner looks to have installed dry rods but has drilled them into the brick and not the mortor course. Will this even work?
I am very tempted to do this again but properly.
See images below that show the dry rods into brick and the rising damp we get on very wet days.
Any advice would be very welcome
