- Joined
- 18 Feb 2007
- Messages
- 1,410
- Reaction score
- 79
- Country
I have a GardenLine Garden Vac, The original Collector Bag failed Very Quickly with a Hole in it. A manufacturers replacement suffered the same fate. I think the Manufactures Bags are not worth replacing as they Hole very quickly. I Purchased a so called equivalent Universal replacement, I managed to manipulate its fitting to the Machine. The construction of the replacement Bag looked good in that the material from which it was constructed had the appearance of being water resistant for the occasion when damp leaves are encountered.
When I tested it, the collector bag inflated like a balloon, but the suction of the Vac became very limited and useless at picking up dry leaves. If I opened the zip on the bag, air flow immediately re-established and suction at the pick up nozzle returned to normal. Pretty useless really as the leaves being picked up just discharged from the collector bag.
The problem is that as we all know the collector bag acts as a filter to let the air flow through the machine whilst the bag retains the leaves. Inspecting the material from which the replacement bag is constructed it appears to be incapable as acting as a filter as there appears to be a water resistant coating on the inside surface of the bag as such not allowing any air flow through the machine and as such suction at the pick up nozzle becomes virtually zero, making the Machine useless at picking up leaves. Obviously the bag does not act as a filter and is identical to just strapping a Polythene bag to the machine discharge and blowing it up like a balloon
The only possible solution my simple mind can dream up is to use something like a Knitting needle to puncture the bag in several places such that the air flow is
re-established and hopefully keeping the Filter function of a useable pick up bag. Obviously if my half brained Idea fails the bag becomes useless.
Has any 'Smart Guy/Girl' any better ideas to try before I embark on what maybe total destruction of this useless collector bag. The suggestion of buying an original manufacturers replacement bag is not practical as they are good as a filter mechanism but not a good design because any small amount of moisture renders the bag useless.
