Plug in solar panels and the meter
19 Nov 2008
Dorset
I've just heard about plug in solar panels, which sound interesting.
I had panels on my motorhome, and they charged 12v batteries and could run a laptop or tv, so for me they're useful.
What I want to know is, as these are mains plug in, does the meter run backwards, when producing more electricity than used, so giving the grid extra power, for no benefit to me, but this would help the grid and country. ( for any do gooders.)
C
It seems not. Long thread about them here if you are interested.
Hi J,
I started reading your thread, but I don't want amateur guesswork and conspiracies, and it's too long for me to read, but thanks.
C
No, solar plug in doesn't charge batteries so can't export.
Hi D,
I didn't ask about batteries, only the meter and grid.
C
You can only export with additional hoops to go through. Meters can't run backwards.
This is for plug in solar which is meant to be a diy approach of course.
Only very very very old mechanical spinning disc / analogue dial meters (sometimes called Ferranti meters) could ever run backwards... AIUI.
Plenty of anecdotal reports of such meters running backwards with early solar installs.
Modern smart meters might record solar export in a separate register (but that register might need enabling via a supplier?).
Did you read all of the link I posted?
It states, that smets2 will reverse.
C.
No. Why would I? You want me (and others) to read something specific post it in plain text and add the source as a link should I desire to follow that...
And the world is flat, too!
The modern Smets2 measure Import and Export separately.
They won't count down the Import Register when Exporting current from a solar (or battery) system to the Grid.
Don't believe all you read on the internet.
I totally agree with virtually everything you have written in this thread, and associated threads - but I don't understand the "so" in this sentence you've written. Having batteries isn't a pre-requiste of export - and, indeed, I woud imagine that the great majority of those who export do not have batteries.
Yes, clumsy of me, I edited the next post I made to clarify but even that one doesn't sound quite right either.
We have had a succession of meters, the old turning dial meter has been known to run backwards, my old digital meter only recorded import, the new digital meter which was fitted with my solar flits from import to export, and my smart meter also records both import and export, but to be paid for export you need a second MPAN number, as in theory you can be paid for export from a different billing agent and who you pay for import.
In the past you could have two different meters one for import and one for export, and could also be paid for export by assuming what was likely, but today only two ways to be paid for export, one is an old meter running backwards, and the other is a smart meter with two MPAN numbers assigned to it.
Not a clue where that comes from? Plug in solar will likely export, no way to stop it, but to be paid for export, you need a smart meter, and need to complete the G98, with installed solar normally the installer would submit the G98 or G99, and since until August 27th you can't legally use plug in solar, we have no idea of what changes there will be to G98 to allow it to be completed by the householder.
The whole question as to what one will gain with plug in solar, remains open, as to date, all the youtube videos I have watched, the people already had solar, so second MPAN number, or they had batteries.
I can see my use, and work out likely results as my system 7.5 times bigger to plug in. But there are so many other variables, my installed system makes me money in three ways.
1) Input from Solar.
2) Smoothing and transfering energy due to battery.
3) Use of an off-peak supply.
They all work together, and it is nearly impossible to work out gains from just one.
I have three tariffs, off-peak 8.625p/kWh, export 12p/kWh and peak import 32.277p/kWh the latter is higher than the standard rate, so I need to use enough at 8.625p to be worth paying the extra with the 32.277p, so with only 800 watt and no battery, it is unlikely you would even break even using an off-peak tariff.
But it seems the limit is 800 watt per circuit, so 4 ring finals in this house, so 3.2 kWh could be generated, if I get rid of all lighting plugged into my ring finals. Not a clue why it states that, seems daft to me. However unless being paid for export, it would be daft to have multi-units.
It seems the DNO has to issue the MPAN number, not the billing agent.
The new proposed amendment says the installer can be the customer, with a simplified form.
