I’ve moved this from general chat as it’s gone past that point now. Looking for some advice. Open up the quoted posts to see videos. They may only be up for a few days as they are from a free site.
Troubleshooting - and it’s not even 7.00am!
For the last couple of mornings, when I’ve given the toilet its first flush of the day, I’ve heard a vibrating noise going through the house for a minute or two. I put it down to a dodgy fill valve making a noise just as the cistern is coming to full. This morning it just kept going and going, really loud. Even turning other taps on and flushing the toilet made no difference. I went into the street to turn it off at the meter and the cause of the noise was immediately obvious - the noise was coming from the water meter. I turned it off, then back on, noise gone. I then made a cuppa and as I turned the tap off, I could hear a slight buzzing that wasn’t going away. Again, I went outside, this time with my phone to record it. This was nothing compared to the earlier noise. The meter is not showing any useage so it’s not a leak between the meter and my house.
Been on to Essex & Suffolk water and they are sending an engineer out. They seem to think it might indicate a leak before the meter?
Sorted. Well, almost. Engineer came out, tested water pressure (4 bar) and witnessed the noise. He took the meter out, gave it a shake and said they shouldn’t rattle like that. He didn’t have a new meter onboard so he fitted a flow cap so we’ve got free water until another meter can be fitted. He took a photo of the reading and asked me to do the same in case there’s any dispute about usage later on. He said I could fill up my swimming pool and everyone else’s but I mustn’t use a hose.
Great service from Essex and Suffolk water. 10/10 from me.![]()
I spoke too early! Flushed the chain this morning and got the noise. I had to go out and check that they hadn’t fitted another faulty meter.
They hadn’t!
After I cleared the noise by turning the water on and off again, I went inside and turned the tap on and (slowly) off several times. No noise. Turned it on and (quickly) off and the noise was back.
Once it has started, turning taps on indoors makes no difference so it’s not as if there’s a tiny leak after the street stopcock and anyway, yesterday there was no movement on the meter when it was turned on or off. Could it be the actual stop cock in the street. Getting really annoying now, I can hear it all the time.
Any ideas?
