Sourcing Zebra (Day & Night) blind for a 240cm width window recess
16 Nov 2013
Kent
Hi all
I've got a fairly tight brief from my better half (no, not my Speedos) to install a Zebra blind in our kitchen. The recess is 2400mm wide and I'd like to install a single roller blind inside it. I know the width is quite a span, so that's a challenge to sourcing it from the kick off.
The last bit of the wish list is that it needs to be a shade of purple/Lilac : - )
So, a zebra type, wide, and purple... Just wondered if anyone has come across the best seller in the world that has everything, or one that supplies the blind fitting trade or whatever.
I've seen a few online custom fitting companies' offerings and apart from their limited range of colours, they do seem a bit steep as I don't mind cutting down a long "stock" sized one an doing the donkey work myself.
Cheers
You can get roller blinds up to 3 m wide. You could buy the roller kit and purchase fabric separately and make your own fairly straightforward..
Cheers J. Thanks Foxhole, I hadn't thought of a roller kit. I'll have a punt around. Have a good one!
