10 mm speedfit elbows
Yep, you just need to make sure that the copper is straight, round and smooth. As 10mm copper is typically soft annealed (R220) coils, as against half hard =>15mm, it can be misshapen quite easily and would then cause sealing issues. Compression or solder is the usual option.
