Hi, I have a 20mm MDPE incoming main, which reduces down to 15mm copper straight after the stopcock. Will this be adequate to supply to an unvented cylinder?
(Family of three, with two shower rooms, though both are never/very rarely used at the same time. Would be easy enough to change the 15mm pipework between stopcock & cylinder, if that would improve things).
Tests below done using an outside tap (with kitchen tap fully open for dynamic pressure/flow readings). Stopcock is at the front of the house & kitchen/outdoor tap are at the back. Cylinder will be on the first floor, almost directly above the stopcock.
10th Mar @ 6pm:
• Static pressure = 3 bar
• Static flow = 22+ lpm
• Dynamic pressure = 2 bar
• Dynamic flow = 12 lpm
16th Sep @ 8pm:
• Static pressure = 2 bar
• Static flow = 12-14 lpm
• Dynamic pressure = 1.6 bar
• Dynamic flow = 10-12 lpm
10th Mar @ 6pm:
16th Sep @ 8pm:
