It seems that the connector strip sizes do not follow the mcb rating sizes.
So if you were working on a 32A 4mm radial and wanted to branch off, if using connector strips would you have to use 60 Amp connector strips or would using 30 amp ones be ok?
I am guessing by the BS7671 regs you would have to use 60 Amp connector strips to support the full 32Amps.
If so, why are 32 Amp connector strips so hard to get in store?
