Adding gentle circulation to vented system
10 Feb 2007
Cumbria
I want to add circulation to one heat dump radiator very near to cylinder on a vented system. Its supposed to Gravity Circulate but it would have to be higher than the cylinder (3 foot) on the landing to do it naturally!
I have a Grundfos circulator but fear this will just cause "pumping over" if too close to cylinder and F&E pipework (adding too much pressure)
The idea was to Gently move the heated water mechanically from rad branch (stove back boiler) through the rad without causing flows into F&E tank in loft!
Is there anything more gentle to circulate than a pump set its lowest??
Cheers
PS. I love sealed systems!
