- Joined
- 20 Jan 2022
- Messages
- 20
- Reaction score
- 0
- Country
Hi All
I've been struggling with a problem with my heating system ever since moving into my house over four years ago. It is a townhouse with four floors and has a Baxi system 60/100 boiler that is getting on a bit but seems to be functioning fine on the second floor.
Air is getting into the system, which collects in the heat exchanger within the boiler (the highest part of the system except for a single radiator in the loft).. If left for more than a day or two, the air blocks the flow of water through the heat exchanger causing kettling and it overheats cutting off the boiler. The water pressure rises slightly whilst this happens. There seems to be no evidence of any water leaking from the system.
I have been managing it by running the heating in the top radiator in the loft daily. You can hear all the air rushing through and I can then bleed it though the radiator vent.
Over time I have replaced the heat exchanger, pump, auto air vent and flushed the system a few times. I have also got a plumber out to look at it who recommended replacing the boiler. I'm happy to do this, but am reluctant as I'm not convinced it will fix the problem. The issue doesn't appear to happen in the summer when just heating the hot water tank. This suggests to me that it is a problem with the heating system/associated pipework.
In terms of next steps I'm thinking of:
1. Adding some leak sealer to the system (not convinced this would work).
2. Shutting the radiators off and running the heating through one at a time per day to try and narrow down where the issue might be occurring (waiting for it to warm up before I can do this properly).
3. Adding a loop in the pipework that is slightly higher than the boiler and installing an auto air vent.
4. Adding an auto vent to the radiator in the loft and schedule the heating to run up there for 10 mins a day. This seems like a bit of a bodge to me.
Any alternative suggestions or recommendations would be much appreciated. It has been getting on my nerves for a while!
