We have a utility room made from Airated blocks, insulated warm flat roof - installed a few years ago
the extension room may have been built in the 80's
Width 2.5m , Height 2.1m , length 5.8 m
Putting an insulated suspended floor - 40mm celitec and 22mm floor boarding on a concrete floor
Room BTU calc on bestheating = 5600 btu
400x600 = 2333 btu
800x600 = 4666 btu
But I could instead of the 800x600 add in a 1000x600 (cheap price as well £60+ screwfix = 5832btu = and not have the 400x600 at all - makes things so much easier and less hassel connecting up to the new heating
most likely going to do this now .... - i was concerned if 1 was enough for the space - BUT it will have to be i think , the alterantives are just too expensive and hassle
i was going to install a 400 wide type 22 radiator one end of room (size restriction ) But this maynot be possible now and a 800 wide rad at the other end
I have a picture below - all worked out
BUT Now , i have looked at where the pipework was going up the old soffits into the roof space - as already hot/cold pipework there - BUT i have the old house cavity wall and so its proving a bit difficult as to what to do and to get the pipework upto the valves - as its such a small width 52cm (i was happy for the valve to come over the door architrave
will a radiator at one end of the room, heat it up enough ??? then i will just put a 1000x600 at one end, as i have now worked out the space available which is 1300 - so 1000 + connectors and a therm valve would fit perfect
or maybe electric - but thats a lot of power
the boiler is NEW and will support the additional radiators
I will come back and edit - and make a better drawing later
EDIT - Now thinking of just 1 rad at the other end of the room
1000 x 600 type 22 = 5832 BTU
400x600 = 2333 btu
800x600 = 4666 btu
