You may be bored with this but i have read through all the answers and i'm still stuck
My house is about 16 years old and i had my boiler changed about 8 years ago to a Worcester Bosch 24i junior combi.
A couple of years ago i had a kitchen extension so the radiator was moved 6 feet into the new bit, since then that radiator has got worse and worse until it stopped altogether ! So thinking that it was blocked with sludge i decided to buy a new rad and move it through into the conservatory
so after connecting everything up and refilling the system i fired up the boiler bled all the rads but the new one doesn't get hot ! even the pipes are cold.
I have tried turning all the other rads off but nothing the boiler just turns off !! If i bleed all the water out of the rad so the hot water has to come through it gets warm around the valve but when i stop bleeding it goes cold again
Please help...
Please help...
