Hi, I have an old Apollo Myson 30/50B Gas Boiler
When the Boiler is cold l can get the pilot to light and stay on to fire up the Main Burner. After 10 minutes they both go out. I can then get the pilot to light but will not stay on after green button on Honeywell 4700e Gas Valve is released.
After leaving for 30 minutes till boiler is cold above happens again.
Have lit Main Burner on High & Low setting no change. Have had Thermocouple and Gas Valve replaced no change. Have Slid Green button to right, waited 3 min as per cover instructions, pressed in Green Button for 30 or 60 seconds no change.
Any suggestions l can pass onto the Corgi Engineer to fix this boiler while l'm saving up for a new one ?
