i have an apollo fanfare 15/30 si with an open vented system . The clock has stopped workingand is broken around the casing , i also have had a problem with i think the hot thermostat... the boiler will start and run for approx 1 hr then turn off , it will only turn back on when it is completely cold , normally after 4 hrs or so .
Question is do i have the boiler repaired or do i go for a new one . currently it is warming 7 radiators around the house. If so what would be the best system and roughly what would it cost to replace, regards, Steve.
