Basin 20mm hairline crack...
16 Nov 2007
Cheshire
Instead of using brain I've used force and created small crack (20mm) on the basin outlet, any ideas how to fix it? It doesn't leak but you can see dark line and it annoys me a lot... Is there any paint/filler/sealer that I could use to get rid of it?
Thanks for any advice...
they can last yr or months. not much you can do its cracked.
if its new take it back say it was cracked before installed.
You would have to make it a bigger crack in order to be able to attempt to get something in the gap to try & "fix" it.
In the end it will make matters worse.
If it does not leak ignore it or replace the unit.
