baxi burmuda 551
6 Jun 2011
Cheshire
No heating no hot water. Pilot light stays on but nothing else. Any help constructive help is appreciated thanks.
Does the boiler fire up at all when the programmer calls for heat?
Can you hear/feel zone valves or pump working when programmer calls for heat?
Does the programmer have power?
hi the boiler does not fire up when calling for heat. Get nothing from valves and pump. Programmer has power.
I suspect the actuator has failed in the zone valve.
There may be a lever on the side of it you can move by hand.
