Hopefully someone could tell me how to sort this problem out or if i need to call out a service engineer. Basically i came home from work 2 days ago to a cold house so i checked the boiler as a starting point and noticed that the pressure was at zero and the cupboard was soaking. I quickly found the source of the water as my Magnaclean leaking from where the big cap screws on. I gid a bit of googling and found it was quite a common problem and possibly just the O ring washer. Some information mentioned taken the cap off and looking to see if the o ring had degraded and replace it. I found information from Magnaclean about servicing and cleaning so i did what is said - found a bit of sludge build up so cleaned it of rinsed the Lid with the o ring washer as it felt a little gritty. Put the Magnaclean back together turned on all the valves and power etc....re pressurised the system as instructed via the filling loop valve to get up in the morning and the heating is off. Pressure is back at zero but Magnaclean is bone dry and hadn't leaked as i even left a pan under it just to check for random drips. and that was bone dry too. o re-pressurised the system via filling loop again bleed radiators to check no air was trapped but again it was at zero this morning and everything bone dry, so i re pressurised it again and watched as the heating kicked in and the pressure rose quickly to over 3 bar so i tuned the thermostat down heating knocks itself off and returns back the the green zone - around 1.5 bar. If i run hot tap water its fine and pressure dial doesn't move only when central heating is on.
Any tips or assistance would be great before i call someone out and spend a small fortune.
Thank you.
Thank you.
