Hello!
Could any of you helpful people point me in the direction of a layout plan/diagram or similar for a combi boiler with the bells and whistles?
I’m not trade and really looking forward to putting together a lovely setup (visually as well as correctly arranged in the eyes of a plumber).
I’ve nearly bought all the bits:
Intergas Rapid 32, OpenTherm’d to 12 Drayton Wiser TRVs - boiler at highest point, in loft, loads of space around it.
External 8L Expansion Vessel
Intergas System Filter (like magnaclean)
Drains (below boiler and at lowest point).
Remote filling loop with double check valves and pressure guage, situated directly below the boiler in a utility room 5 metres away
Automatic bypass valve at end of new flow and return
Intergas Outside Sensor
Frost Thermostat for in the loft (cold roof)
Want to add various isolation valves and additional vents if it makes sense to.
Existing CH circuit to existing house needs connecting (can’t disturb that side at all really other than getting to the 22mm flow and return)
New part of house will have the new flow and return (7 rads) with bypass on end.
All in copper.
Like I said I’m not a plumber so if I’ve got anything wrong feel free to tear me apart.
Thanks!
Edit: also interested to add some sort of dosing system as I believe I need like 2L of inhibitor for this setup so I’d like to include whatever the best method is for adding it down the line in the most convenient way in the years to come.
2nd edit: also forgot to say this is feeding my shower, only one bathroom, only shower or bath used at one time and not together. Also there’s no underfloor heating
All in copper.
Thanks!
