Best practice installing Neff electric single oven and hob
20 Jan 2006
I have a Neff single oven (2.8kW) and electric hob
(7kW) to install (was to be a gas hob so no planning
was done)
There is a cooker switch with 13A socket on the wall
but no apparent further terminal box. The kitchen
currently has a freestanding gas cooker with no
electric connections. The switch is apparently
connected to the consumer unit with a 30A fuse. (max
load 63A currently full with 2 x 5A & 2x30 ccts
(cooker and sockets))
The hob has a cable attached (which according to the
manual is Y type with no user service). 2 cables
6x1.5mm2 plus earth
The oven has standard terminal connections.
I also need to install a 120W extractor fan.
question 1
Can I spur both the Hob and the cooker from the same
terminal box?
Question 2
If so, could I do this without installing a terminal
box?
question 3
What size cable should I use?
With the cable on the hob being approx 10mm2 and the
total power being 9.8Kw, I reckon the hob would take
the whole 30A cct and I would need another 13A cct
for the oven. :(
Could the fan and hob be run from the cooker cct
(changing out the switch for one without a 13 A
socket) AND I run the oven from the 13A socket cct?
:idea:
Or could you suggest other options?
I may just bite the bullet and install the gas hob I
have instead.
