Boiler keeps turning itself off....??
4 Mar 2010
Suffolk
Hi all my central heating continually turns itself off and wont restart for 10 15 mins
Im trying to find out if this is an elctrical or plumbing problem??
The boiler is a Vaillant ecotec plus 612 condensing, when it goes off ,,
the code S.30 appears which states "room thermostat 3/4 no heating demand".
The room stat brand new and is a Horstmann hrt3.
Any ideas what the problem could be ??
Many thanks in advance
Jon
Right I've referred to the instructions of the boiler , removed wire from 4 linked 3 &4 together and the boiler now comes on fine.
Does this mean i have dodgy room stat??
Does it start without you re-starting it ?
When the boiler has switched off can you hear the circulation pump running ?
A stuck pump will cause this. The heat in the boiler exchanger will linger for a long time if the energy is not removed by the pump. Say 10-15 mins
A massive air lock can stop water circulation.
Is it cycling due to the hot water in the boiler not being dissipated in the radiator circuit therefore boiler stat over rules
Note : if the boiler is supplying more hot water that the radiators can dissipate it switches off, but the pump must keep running.
Are all the radiator valves fully open, including the lock shields ?
Are any radiators getting hot. Some will even if the pump has stalled by gravity feed.
When it is on, does the room stat, when clicked to a low temperature switch the boiler off ?
Just a few questions off the top of my header tank
Regards flounder
Before i go get a new stat can anyone tell me if this one is wired correctly??
Red is going to 1 ....Line
Black is going to 3....Load (Heat)
Green is going to 4.....N
having just traced the cable back to a Honeywell "junction box" the other end of the green cable is with all the earths?? but if i disconnect it from the stat the led light goes out!
Many thanks
Jon
