Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Help! My boiler pressure is on 3bar when I understand it should be on 1bar. How can I reduce this to 1 bar? Can it be done via the radiators, or at the combi itself. The combi make is a ferroli F3
First bleed the rads and see what happens.
If the cold pressure is still too high ( look in boiler instructions for correct pressure) then simply open the drain cock and drop the pressure that way. If it drops too low then refill with your filling loop..Easy...
Warning flag raised by the pressure being at 3 bar! Is the pressure relief discharge pipe (outside, hopefully) dripping? Is the filling loop "letting by"? Try disconnecting it - which it should be anyway. If there's anything wrong you need to get it sorted or you'll fill the boiler with scale.
