Boiler replacement - what steps should be taken?
17 Oct 2006
Manchester
I am having an old Worcester 240 RSF replaced soon and was wondering what things should be done on the day of the job?
I know my 15mm gas feed is to be changed to 22mm and that a soakaway is to be installed but is there anything else that should happen?
I have had a few quotes and some have talked of a straight swap with the above steps and one said they will put some cleansing fluids in the system and use the old boiler to run it through for an hour or so to clean the system? The different opinions and approaches have made me a bit wary and confused.
Any tips are greatly appreciated.
Some are going to do it properly and others are going to cut corners.
I notice none are to powerflush.
Manch has a lot of poor quality jobs because most want them done cheaply and so they end up with a cheap job.
Tony
Thanks Tony,
So you think a powerflush is a requirement.essential? Are you saying if an installer does not recommend a powerflush I should steer clear?
Doing one of those on Wednesday.
Powerflushing is over rated and quite often badly done.
I clean the system as I see fit given the age of the system
and water that comes out.
I shall simply be installing a drain cock on the flow and letting
mains pressure fly around the system from the return.
After the that has run. I take the customer and I show them
the water that is coming out of the central heating.
That way there are no arguments. Customer has seen it.
Power flushing is the best way to clean a system.
It is not always needed.
I clean the system as I think necessary BUT then I fully guarantee my installation in all respects.
Tony
Thanks guys.
So a power flush is not always required.
The system is probably around 15-20 years old and some of the rads are not as hot at the bottom which makes me suspect sludge build up?
DCawkwell, is it fair to ask the installer to do a mains flush and show me the water as it leaves the system?
