Bosch Dishwasher not washing
18 Aug 2009
Tyne and Wear
My dishwasher fills then makes a feint buzzing noise, timer goes round at the correct(ish) speed, then it drains, without having washed the dishes at all
any ideas???
don't know if its worth mentioning but this stood in a garage fro about 12 months, then was used by us for about 2-3 weeks ok before this happend. It didi happen when we first turned it on but then started working ok
cheers
circulation pump seized or impellor and seal jammed not a cheap fix .
thanks for the help
at 21 quid its worth a go, only thing is the pump shown is for a SRS4302GB/02 ours is a /03 don't suppose you know if that'll fit.
Hi forgot to post back, I got that pump and fitted with the help of some zip ties, as the casing was very slightly different to the one in my pump. Works a treat.
cheers for you help.
