Bosch washing machine
22 Mar 2008
Avon
Hi all,
Has anyone ideas why when doing a wash the water takes in my conditioner at the beginning of the cycle.
Any advice would be much appreciated.
Thanks.
I occasionally get this. In my case it's caused by a build up of mould on the water inlet holes above the soap/conditioner dispenser tray.This causes the water during the first fill to spray not only into the soap dispenser but also into the conditioner dispenser and empty it.
A thorough clean with a toothbrush and a pipe-cleaner to ensure none of the holes are blocked should cure it. It helps to remove the dispenser tray when not in use to enable air to circulate.
Thank you very much for the info, i will try this and hopefully it will work
Thanks again.
