Building a rainwater soakawap / sump.
  • Thread starter Thread starter BFG
  • Start date Start date
BFG
8 Feb 2003
Hi all. For my first post, I'd like to propose a problem.
We have a 1930's property with a mains sewer at the rear. The guttering at the front of the house empties into (we presume) a soakaway blocked this long time and beyond clearing due to a winter jasmine growing up the house.
The plot is clay soil, and slopes from the road/driveway, down to the house. The garden gets standing water after heavy rain.
At present, rainwater from the downpipe spills onto the hardstanding and is already causing a problem. So we need to resolve this fast.
What I am proposing, is to dig a new soakaway, about 10 feet from the front door. Then I plan to have a perforated pipe drain the garden, and a trough run for the rainwater, so that they both empty into the soakaway. As we're on clay, I have an idea to install a pump, which will take water from the soakaway (or sump, as I've heard it called) through a pipe sunken into the path around the house, to empty into the swere at the rear.
Has anyone done this? Can I expect any problems? Is it over the top? Any advice appreciated. :)
in some parts of the country its against the regs to dispose of rainwater into the foul drain. (this doesn't mean that it doesn't happen!!!)
also the current building regs call for a soakaway to be 4m from the nearset building. which is not always possible.
normally it is poosible to just dig up the old soakawat drain and replace that as they tend to be full of plant roots.
the actual soakaway is normally OK
good luck
aleks
Hi, many thanks for the replies.
The regs for soakaway is 5m. But, I can put one in as there is an existing soakaway. Also, if I put a sump, this is sealed and doesn't count, so can be closer. If I site the soakaway 5m away, it will be untenable due to the fall of the plot. Currently, existing rainwater is running into waste sewers for the whole street, but thanks for the warning. I'm very grateful for the suggestions, it will add to the research and planning I've already done.
I'm looking for advice from people who have actually done it. And advice on which pumps last best, which switching method to use - floating switch etc.
Make myself, or go ready made: http://www.amospumps.com/sewagesumppumps.htm
I couldn't get the link to work, Screwfix pages do that sometimes. go to www.screwfix.com and enter part number 19569 it is a sump pump with float switch
That's great info - much cheaper than Machine Mart too. Thanks :)
I had another suggestion from elsewhere to use a plastic cold water tank as the sump, rather than try to dryline concrete. I'm not sure how it would endure. Obviously water contact wouldn't be a problem, and neither would the usual plastic killer UV. But I wonder about frost?
