Can you plumb a WC into a vent pipe?
17 Mar 2008
London
Hello, I'm new to this site so please be gentle! Got a utility room and down stairs toilet to install and was seeing if I could plumb into the vent pipe running down to side off the building? The man hole cover is on the other side of the wall but would be a lot quicker and easier to connect into vent pipe. Have looked at Doc H but can not found anything regarding plumbing into vent pipe? Any advice would be appreciated.
Is the vent pipe of which you speak a 4"/110mm soil stack?
If so, then what is the distance from the ground to the point at which you intend to join it, and what is the distance from there to the top of the pipe?
Hello Softus, the vent pipe is 110mm and goes above the roof, I intend to connect at the ground level about 500mm above the ground.
From the connection to the top of the vent would be about 3.5/4m?
Hello Softus, the vent pipe is 110mm and goes above the roof...
That's OK then. In principle.
AFAIK you'll conform with the Building Regulations with not much room to spare then; I seem to recall that the minimum distance to the bottom bend (which is, of course, slightly below ground level), is 450mm.
That part is fine.
All this still applies to a vent stack? There are no pipes branching of this vent pipe it just comes out of the ground and up above the roof. If so, I do appreciated your help Softus!
Regards
Lee
But you're about to turn what you call a vent into what I'd call a soil stack.
Two things for you to consider:
1. What is the connection from this 'vent' into the underground system? It needs to be of appropriate construction to become a soil pipe.
2. The work that you're proposing is notifiable to your LABC under the provisions of The Building Regulations.
You need to ensure that the bend underground is a rest bend (slow bend) otherwise you will get blockages. :(
Many thanks Softus and bahco!
Would not do it any other way, I'll always get building control approval!
Just wanted to check if it was possible but will have to do a bit of digging to find out!
Once again, thanks for the advice!
