I'm having a problem with a door hatch/knob. Basically, even when I turn it fully up the door still opens very easily i.e. a wind or even just people opening other doors is usually enough to open it. I have to wedge my door so it doesn't open!
This first happened a while back after I oiled the door lock mechanism but I've put up with it because I couldn't work out how to take of the lock mechanism.
I've read up a but but nothing has been particularly helpful. Most treat taking off the 'knobs' as the hard part. But this was very easy since it just screwed on and the screwed weren't even covered. But the trouble is, I can't take off the dead latch. Everything seems to say it should just come out once unscrewed but I can't get it out. I tried using a small screwdriver to wedge it out but this just resulted in a nasty scratch on my behalf. I've also tried using pliers to help pull it out but doesn't seem to work either. As mentioned, I've unscrewed the deadlatch. But there seems to be some sort of small pin things. I've tried to wedge these out but they're so tight against the surface I don't think I can. Is there something I'm missing?
I've taken som photos of the door knob etc. They're not the best and I can probably do better if necessary (taken with a phone but I have access to a digicam)
(this is of a different door but they're all the same)
Alternatively, does anyone know what's likely to be wrong with my door lock mechanism? Would it be possible to fix it without removing the deadlatch? I'm pretty sure it has nothing to do with the strikeplate (which can easily be removed)
Cheers and thanks for any help
P.S. This is the second time I've tried to remove the deadlatch. The first time was way back when it started acting up.
P.P.S. As you may have notice, the knobs are keyless/can't lock
