Hi all, I need help on some issues fitting the new shower in our bathroom re-firb. I have searched but am still unsure
Firstly do I really need a twin pump, we have a conventional heating system with a hot tank in the loft and of course the header tank and cold storage tank up there too. From the proposed height of the shower head I havea head of approx 2.0 m to the surrey take off on top of the hot tank and approx 3m to the bottom of the cold storage tank. Should this give enough pressure assuming all pipework is 22mm to within 1m of the mixer valve?
My initial thoughts were to leave provision for a twin pump (ie flexy pipes and full flow isolators) when installing the pipe runs to enable fitting of the pump at a later stage or should I just go for it and fit one regardless.
Secondly do I need to fully drain the hot tank to fit the surrey valve or will partially do?
Thanks in anticipation
m.
m.
