I really need some advice on my CH/HW System!
It used to work fine on timer and on 'constant' until I had the water cylinder replaced. It may be coincidence that I now have this problem, but thought it worth mentioning!
Now I can't get HW unless I put the CH on as well.
This was my original WORK AROUND TO GET HOT WATER:
Put HW on Constant, press CH onto Constant. The heating thermostat light comes on in the hall and the light for the hot water thermostat in the airing cupboard comes on.
You can then turn CH off either at the main switch (by boiler) OR you can turn thermostat down to 'temp reached' .
HW continues to warm up as the boiler stays on and the green light of the airing cupboard stays on
NOW to get HW we do the same but even though I turn the CH off at the main or the thermostat it STAYS ON despite all the physical signs says its off!
I thought it might be the Alternator but we only had that replaced a year ago (after getting excellent advice via this site!). Could it have broken? Is there any way of testing it? It's one of the pop off front ones and the plummer who fitted the water cylinder said he can hear the motor?
Please an anyone give me some pointers?
Thanks,
Lesa
Thanks,
Lesa
