Changing swing direction of upvc window
2 Sep 2012
Blackpool
Im wanting to changing the swing direction of my upvc window. There is no locking mechanism in the window so it should be possible. The only thing Im concerned about is the hinges. At present the hinges are fixed at the top and bottom of the window but I want to change to hinged at the sides so I presume Ill need side hung friction hinges ?? Also how can I make sure they are fitted in the correct position ??
Which way does it currently "swing"? I think you may be getting your top and side hung hinges the wrong way round, what I mean is if the hinges are fixed at the top and bottom as you say then that is already a side hung opener with I presume side hung hinges, either Friction Stay or Easy Clean/Restricted/Fire Hinges.
Where is the (cockspur?)handle? Bottom or side?
The current set up is side hung (hinges top & bottom). The handles are on the side but have no locking mechanism.
What you need is Top Hung Hinges that they do in various sizes from 8" upto 24" depending on the load they are to carry, what are the sizes of the opening sash?
Sorry for the late reply, been a busy weekend! That's a pretty tall opener to be changing yourself but if you do give it a shot you'll need 24" Top Hung Hinges (you need to know the depth/stack of the hinge to suit your profile, I'd also make sure you have steel reinforcing inside the profile as that is a large sash!
