Hello
I have removed and chucked away the skirting in my Victorian terrace (it was mis-matched and in bad condition).
I'm going to lay a floating floor on the boards, and then fix new pine skirting over the top. Some of the old battens remain, and a few of the original wedges are in the brickwork. There is a 7" gap between the boards and the plaster (picture attached) which is about 20mm deep.
1. I have numerous chases/gaps to fill, and I'll be skimming the walls. Is it worth me buying a couple of extra bags of browning/bonding and filling (at least some) of the gap before fitting skirting?
2. Am I just creating extra work, should I just replace the missing battens and fix new 7" skirting over the top? Would you put a lower batten on too, to support the bottom of the skirting?
3. Even though I'll be painting the new boards white, I want real wood/pine - not MDF. Any tips on getting hold of some that isn't/less likely to warp? I presume a made-to-order timber merchant is best, rather than pre-packed DIY store?
4. Would you fix skirting to battens, or screw through to brick?
Advice appreciated, thanks.
