I have a Worcester 24Ri it starts up OK switches on the Hot Water and the Central Heating. However, when it switches off the boiler starts clicking in and out a relay. If you switch on and off the Hot Water then it behaves correctly with no clicking. If you do just the Central Heating then you get the clicking. To stop the clicking I have to switch off the power to the boiler.
I have been through and checked the 3 position valve using the FAQ page and it points to the Boiler. There appears to be a 50V floating around the circuit when the Boiler switches off the Central Heating. If you look again after switch off and on the power to the boiler then this has gone
Is there anyway I can do some more checks to see if it really is the boiler
Paul
Paul
