Cold water pressure drop
16 Jan 2011
Surrey
I have an issue with pressure drop and am asking if this forum can shed any light. I have lived in this house since it was built in 1997. On the ground floor, I have kitchen, utility room and cloakroom (with toilet and wash basin). The utility room with sink and washing machine was professionally added in 2009. Flushing the toilet sometimes, but not always, reduces flow in the wash basin tap to a trickle (or nothing) - probably not unusual. But it has now started to reduce the flow in the kitchen and utility taps as well, and often lasting well beyond the toilet tank re-filling. The washing machine has also started flashing 'H20' indicating that it has low water pressure. When flow in the kitchen or utility room tap recovers, it 'spits', indicating to me that air has got into the system. Once recovered, flow in the taps is strong.
I always thought that kitchen taps were connected directly to the main supply, but in this case, all the pipework is concealed behind kitchen cupboard backs. From the behaviour it seems like they are all connected together. Am I getting some sort of airlock in the plumbing? Grateful for any advice that might point a plumber in the right direction.
Not an airlock. Really need to check the incoming pressure/flow rate in case there is a problem there.
Is your mains cold water stopcock fully open ?
What is the flow rate from your kitchens cold tap ( how many litres of cold water do you get from it if you time it running fully for 1 minute)?
Thanks both; you seem to have hit the nail on the head. I thought the stopcock was fully open but a more determined effort found that I had just hit a stiff spot in the thread. It has opened another couple of turns. I have fully opened it (to a definite stop) and then backed off half a turn. All now seems to be well.
Happy New Year.
