Folks, we have a problem ... and I've probably made it worse. Have a laugh and then tell me what you think might be the problem/cost to fix, thanks.
We came in to find the RWB200 controller on the CH/HW looking like it had no power (nothing in display).
I removed the in line 3A fuse and found it had blown. So I replaced it ... inattentively ... with a 13A fuse. Oops, not my finest moment. The controller went 'POP' (and the RCD on the mains board flipped too)
So apart from the controller needing replacing (it'd be LOL were it not so cold today!) there's a problem with the system somewhere that initially caused the fuse to blow and which continues to provide an open circuit which blows new fuses.
I can clearly replace the controller easily enough - there are plently that fit on the same backplate - but I do not know where to start on the original problem which is blowing fuses.
The boiler is Baxi solo PF (early one ~ 10 years old probably), powering HW and CH. The boiler was NOT running (beyond pilot light) when it blew the first fuse, and appears to have shut itself down.
I'd appreciate opinions please on
- where is problem likely to be?
- are parts likely still available?
- ballpark figure for repair? (less or more than £150?)
Yes, I do realise this is a bit 'long long is piece of string-ish, but that <£150< is the clincher. Thanks. And if further info about system would help please ask. Thanks.
