concrete window sills
15 Feb 2013
Aberdeen
l need to replace 3 concrete windows sills as they are crumbling and have not got a clue where to start and how much it will cost ,and also does my windows have to come out while doing this ????
The window stays in!
A pocket is cut either side of the brick/blockwork then the sealant between the window and cill removed.
Run along the underside of the cill with a bolster to loosen off and if all goes well you should be able to rotate the cill out.
