Hi, sorry if this in the wrong place but im not sure where else to put it.
Im having a large coldwater aqaurium built (around 900 litres) and its going in a conservatory however it gets really hot in there in the summer and i need the the tank to be around 14-16oC otherwise im going to have problems keeping the fish.
I need something to get the room temp down as much as possible (doesnt have to be 14-16oC as i can use other means to get the temp that little bit cooler. Also it needs to have a thermostat so that it'll turn its self on when it gets to hot. However im on a budget (i need it to be cheap as possible). Its also hard to fit anything to the roof or walls (other than the 2ft high brick wall around the the bottom) as it willnt supporting much weight.
Any advice would be very appercated.
Cheers
Phil
Cheers
Phil
