crap job
JPC
10 Aug 2004
Leicester
i'm fitting a saniflow monday. (toilet only variety)
i was going to do it in 22 mm copper (per m.i.) 6 meter run on the outside.
i take it i would have to unsulate this ?
if i did it in 32 solvent weld would it need insulation ? (sldo per m.i.)
does the flush" clear the pipe everytime ? or does it leave residue that could freeze and cause a frozen blockage?
any thoughts ?
jamie
ps not got the m.i. here at home to check
""""rubbish job was not my original title (does not have the same comical value)
Nightmare Job.and with a hard winter coming.......Insulation is paramount, all exposed wastes and even 4inch cast soils,horizontal, have frozen.....that bad winter between `80-87.... :?: nearly killed me :evil: Can`t remember exactly which year .was working for a housing assn. :cry:
The pumps should not need insulation if you use a 32 mm waste with a correct and even fall.
They pump out the effluent in a few seconds and that will be warm and should drain away before freezing.
No harm if its insulated though.
A pumped WC should not be the ONLY one in the property!
Tony Glazier
