Hi all
Fitted a danfoss room stat yesterday as a replacement for a honeywell room stat the was faulty. When i turned the room stat up to call for heat, boiler fired and ran normally. Got a call today that the fuse has blown after the boiler had been running for around 2 hours or so.
The only thing i can recall that was not normal was the roomstat seemed to be set incorrectly. When the room stat was set at 30 degrees it turned off, and when it was set to 10 degrees it turned on. I think i must have wired it wrongly.
Im going to go back and check to see what ive done.
From looking at the diagram (Y plan)
Red should go to 1 (live)
Yellow should go to 2 (switched live)
Blue should go to 4 (neutral)
Is this correct? (only three wires coming from wire to wiring box red, yellow, blue)
thanks
andy
thanks
andy
