I have found the dial at bottom LH side. I turned it clockwise and it started a rinse I think . then after a short while it stopped.
I could not get it to do anything else , so I turned it again .
It went through another small cycle and stopped .
The dial reads stop at the 12:00 position with the number 1 underneath. The numbers on the diagram are printed and run in odd numbers from 1-59.
1= stop 3 = WV1 7=WV1 8 = CYCL 10= WV1 11= CY/V1 and so on .
Can you please tell me where to set the dial and then what programme to run it on , or what sequence this shpould be carried out in.
The machine clearly works still.
On the top RH side of the front of the machine the programme dial starts at the 11:00 position with 1 cold rinse 0 at the 12:00 position and 2 wash at the 1:00 position. Sorry don't have model number, it ios semi- intergrated.
Any assistance would be appreciated
Thank you
Tony
Thank you
Tony
