diplomat washer dryer help amp 8702
5 Sep 2011
Devon
I need some help My diplomat drum spider broke. so i changed the drum and spider. got it all back together run the machine all ok. but i had a small leak from the 4 pin thermistor so took it out resealled and refitted there was my mistake when i changed the drum i did not remove the thermisor just made note of there the wires went. now when i refitted the thermistor it was in a different position so it smoked. I have now had the pcb repaired and got a new thermistor. I just need to know which way up the thermistor goes and which wires go to which pins. ? there are to bent pins on the thermistor and a c shape mark. Two of the wires are white with th on them. 1 is grey and goes to the heater element and theres another grey wire which i guess goes to the pcb.
Hope some one can help thanks Dave
