Apologies if this has already been covered - I dont really get on with the search function on this site!!
My Brandt dishwasher wont drain. I presume hardly any Brandt issues come up, but im also presuming most dishwashers work in the same sort of way, so problem solving is interchangable to some order....
The pump sounds as if its working at some point in the operation, and also more water sounds as though it is going into the machine than is left at the end, so im thinking the fault is only partial, not complete.
Ive check the filtery gubbins inside the machine, and im able to siphon the water out of the bottom of the machine through the drain hose so im pretty sure there is no blockage anywhere along the system.
Are there any further checks i can make to rule-out or rule-in any other parts? or is it a trial-and-error thing having to try replacing different bits until it starts working properly again?
I dont want to pay the call-out and parts cost because the dishwasher isnt worth that much - but I would like to sort the problem myself.
ANY help/advice/suggestions are thoroughly welcomed!!
Peterb20
Peterb20
