drainage parts required
5 Nov 2008
London
I am looking for simple stuff... all solvent weld pipework none of this push fit stuff
100mm 92.5 degree branch in white
50mm reducer that will fit inside the 100mm pipe
50mm pipe in white
100mm pipe in white
100mm end cap
the solvent pipework must be flat on the outside like this:
LL
*I know this is not a 92.5 degree branch*
happy to adjust the figures to 110mm etc if needed...
I've tried, homebase, b&q, plumbase, screwfix, travis, and the like...
thanks in advance all!!
Yes The Plastics Depot do that 0121 311 2666 and will courier out bear in mind the hole in the reducer is offset and not dead centre in the reducer.
