Hi
I'm going to lay an engineered wood floor soon and have a couple of questions.
I'm going to lay most of the downstairs and wondered if i need to put any expansion gaps in the floor itself using door thresholds or could I do one whole floor. The dimensions are roughly 7.5 meters by 3.5 meters (the 2 rooms and small hallway combined) Also does it matter which way the board run?
I'ts also being laid into floorboards. They are pretty level and are very sound. What type of underlay should I use?
When I'm fitting I know i need to leave an expansion gap of 10 mm but what about round a fireplace. Can i butt it right up against or leave a smaller gap or if I need to leave a 10mm gap how could I cover the gap (quadrant wouldn't work as it will end up higher then the granite hearth).
Sorry for all the questions!!
